Stall issue?
cckramer101
Nebraska
New SHO owner, just bought a 2011 a week ago. Have had a random problem the past few days with the car. Usually with in the first 15 minutes of driving I will lose all throttle response. The car stays running in a low rough idle. Shut the car off, wait 15 seconds and restart the car and will not have any issues until I shut it off and let it sit for an extended period of time.(over 2 hours)
TIA
yaycandy
Aerospace Engineer
Hanover, PA
If no codes then start with getting the battery checked or make sure the gas aint 9 years old
cckramer101
Nebraska
Battery is good, and it's the second tank of premium fuel I've ran through it
Also I get the little white wrench that appears
yaycandy
Aerospace Engineer
Hanover, PA
Run codes. Check the map sensor at the noise maker pipe make sure its plugged in. Mine did same thing when i forgot to plug it in
