SS Stage 1's vs SN Plus 20's Cams
AREA 91
PA SHO SHOP
Area 91
Jon, you have been in my green car. Now you can't tell me that those +40's don't put a smile on your face. A cammed Yamahammer sounds nasty.
Now for a True daily driver (no secondary's) I wouldn't go with cams. I'd do a 3.2 swap with 3.0 cams. Torque for the win!
Now if you are building a "toy" cam it up!
Phoenix
SHOHOLIC
QC , Canada
Now for a True daily driver (no secondary's) I wouldn't go with cams. I'd do a 3.2 swap wityh 3.0 cams. Torque for the win!
Quoted for truth. :evilgrin:
GR8WYT
SHOless
Langley, BC Canada
I have the +20's, and there are quite a number of posts in the 2004 timeframe about the results that I gained from just the cams.
As stated, you don't lose torque it just moves up the rev range. Without intake mods my car pulled 216whp with +20's. True, the car lacks the tug of low rpm torque, but it pulls like **** all the way to the rev limiter. Fantastic!
If you want big power, go forced induction. If you want a thrilling high rpm wail, go for the cams. I'm all about the motor...
GR8WYT
SHOless
Langley, BC Canada
Oh, and there are zero quality issues with the cams that Shonut sources. I've been to the shop where they are made. ;)
SuperHO
Mental Patient
St. Joe, MI
silly canadians and their fake money...anyway, i've experienced both +20s and a 3.2 swap, and i'll have to agree with hairball up there with the engine swap being more streetable. i rather enjoy being able to pass at speeds about 60mph without having to downshift out of fifth. my next mod will be a pretty purple bottle plumbed from my trunk to my engine bay...that'll have to suffice for me until my turbo build on the V8's finished...at which point i'll join the ranks of turbo'd gen IIs. and when i boost mine, i'll be sticking with stock 3.0 cams.
Sho Amo
SmkTyresntDrugs
Olney, Md
also wanted to know if you need a tweecer or any tuning for them
yamahaSHO
E85 whore
Arkansas
You dont need a TwEECer for them, but you certainly can do some tuning with them.
jon93
Philadelphia Region
mmmmmmmm cams! You will need to at the very minimal raise your idle to around 1100rpm with cams.
GR8WYT
SHOless
Langley, BC Canada
My car idles quite happily at ~900rpm. Even got some props from the Alpha guys last summer at the 2008 Convention track day. "Sounds mean!" :woo-hoo:
yamahaSHO
E85 whore
Arkansas
Mine did fine at 900 as well with stage 1 cams and a stock flywheel. I only raised it to 1144 to quiet down the blower at idle.
With stage 2 cams and a light flywheel, it will idle just fine, but dies when you let the revs down too quickly. That can be fixed with tuning though :)
Sho Amo
SmkTyresntDrugs
Olney, Md
okay kool.
if i needed to couldnt i just turn the idle screw on the tb?
yamahaSHO
E85 whore
Arkansas
Nope. Computer controlled cars will ALWAYS... REPEAT, ALWAYS try to run what they are programmed to do. It WILL learn itself back until you go so far out of whack that the car will run like crap.
