i'm trying to lower my SHO but i'm getting KYB's all around, what springs can fit well with KYB's and still lower the SHO somewhat? would intrax or eibach mix well with them?
Both/either will. Depends on your "stance" preference... I feel the Intrax lower the car a "bit" more than the Eibachs do. Either way....You can't go wrong..
From what I've read here on the forum, KYB struts will not perform well with anything more than the stock springs. The struts can not handle the Eibach / Intrax springs, and will need to be replaced by the time your next oil change is due. If you're content on lowering your SHO, I would go with the Tokiko struts all around. You'll end up paying a little more, but your ride will be mint and you won't be replacing the struts again anytime soon.
For more feedback, do a search here on the forum using the phrase: KYB.
