sho 'nuff
I am trying to diagnose this issue that has been ongoing for about a week now. Intermittently I lose spark from the two middle wires on the coil pack. I thought it was an issue with the coilpack so I replaced that and it ran fine for a day and a half and now the issue is back. The wires and plugs are less than a year old. Could a bad Spout connector be causing something like this? Should I check out replacing the DIS module and see if that does anything? HELP!
Also could I mess anything up by driving it with the two cylinders out for say 20 miles?
I tried to run the codes, but I really suck at trying to figure them out. I'll get like the first two or so and start getting confused.
I am pretty sure I get one relating to the BARO(?) and there were two related to cylinders, which I assume would be due to them failing.
