fasteddie
Speed control servo asymbly / and No Brake lights
Ok here we go my brake lights stoped working, and of corse the shifter wouldnt come out of park, so I thought must be the boo switch. Just for the **** of it I tested all my fuses and found fuse number 1 a 15 amp blown so I replaced it, and it instantly blew again. Obviously a short I Checked all the bulbs and found no problem with them or any wirring. I started to trace the wire and I found it lead to the speed control actuator aseymbly located behind the throtle body and I smelt the burnt wire odor. I pulled the harnes and noted the 2 right ends closest to fire wall were smoked and a little melted so i made sure the harness was ok and with it disconected I have no short any more, and the fuse dosent blow. Now the big question is why is this module doing this,and what do I do to fix other than buying a new one from the dealer and hoping the problem is fixed??? Do you have any help on this or direction I should go in. 94 atx 3.2L
