Spark plugs a-poping
90ford
Milwaukee
I have a 90 SHO, mtx and still is as strong as ever besides the body work.
ever since a few months ago one spark plug poped out while driveing and its sounds like a poor harley running. then i found out that the spark plug stripped out the head and i had to put a thread savering the the head and now it works but now another plug came shooting out and i was woundering if that is caused by the alumnium head fatigueing??????????? the car has over 190 k miles on it but it still can kick alot of ass :thumb:
1slickRED89
Guest
Toledo Ohio
they might not have heat treated the head right at the factory, I can't imagine how it could pop out.
they had the same problem with the 4.6L 2 valve but that's a half thread hole and when you get (( non-torqued spark plug + minimum tolerances threads) + non treated heads ) = only 2-5 threads engaged = liberated plugs
SASHO91
Zoom Zoom
San Antonio,TX
hate to be the bearer of bad news, but it sounds like your gonna need some new heads. Not unless you take yours off and have a machine shop redo the affected plugs. then you could run different sized plugs in those. (dont know if thats possible or not, but it sounds plausible)
or better yet, find a 3.2 and drop it in.... :naughty:
hawkeye18
Sorta cares
Norfolk, VA
that's friggin' weird, dude. I've never heard of that before. Yeah, sounds like you got some bum head.(s) I think Josh has it right when he says to drop a 3.2 in there :p. But yeah, at the least replace the heads. The whole assembly is suspect.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
thats somethig ive never heard of myself... well if you need heads i got some 3.2 heads i cant seem to get rid of... id let em go for cheap since you got a 3.0 ........ for the love of god someone need heads..... **** ill even gasket match em
90ford
Milwaukee
i really dont want to replave the heads cause of $$$$$ issues but i found out that save-a-thread works well in the head cause u install a steel thread into the aluminum head the spark plug doesnt pop out any more and its a cheap fix untill i get MORE $$$$$$
Unless some one would want to buy some parts off of me cause i will sell the car as a whole or i have a catless and catted y-pipe, black body kit, stock MAF but i have many upgrades on the car
__________________
90 MTX 3.0, 73MM housing with stock sensor, bias plugs, new clutch and flywheel, new tires, new rear claipers with working e-brake, airfilter housing cut wide open, k&n filter, catless y-pipe custom 2.25" exhaust duals (2-1-2), custom a/c delete w/cable hold down, shorter shiter, GM spoiler from a lumina, solid sub frame bushings, lowered front and rear, white faces gusges,
