sounds like rocks in my water pump?93 auto
"SHO"time
shostopper
Detroit
can i change just the pulley ? is it easy.i sprayed wd40 on the belt and the noise temporarely goes away.i changed the belt and the idler pulleys and its still there.any advice anyone.
wood_e
The dude
Ames, IA
[QUOTE="SHO"time]but its not overheating .the noise is annoying.its not leaking .[/QUOTE]
Just because there aren't classic symptoms of a bad water pump here the pump bearings are toast. Once those give out, then you'll overheat... its only a matter of time. You would be smart by changing it now than having to have your car towed when it overheats.
313tiger
