Sound like CPS?
rendyx
Buffalo, NY
I accidently posted this in the open forum, so I'll copy all the info here:
Yesterday, Jason (yamahasho) noticed that there was a bit of coolant under the water pump on my SHO. Today, driving along, with the car just starting to warm up, I pushed the clutch in to shift to 2nd, and she stalled. First attempt at restarting did nothing, a minute later, it worked. I suspect it did so in such short time if a a very small amount of barely hot coolant hit the CPS, and only bothered it momentarily (sp?).
Just ran codes, and got 41 (system lean, rear bank). This may be my mysterious vacuum leak which must not have been from the secondaries vacuum canister.
When running the test, I did notice when I tapped the throttle to do the cylinder balance test, there was a metal-rattling sound. This occurred the next time I tried it. However, after pulling out my paper clip, and restarting the engine, I tried tapping the throttle twice and did not hear any rattle.
Any thoughts? Thanks! :)
rendyx
Buffalo, NY
Another note, my fuel pump makes a bubbling noise along with the usual hum when I turn the key to run, and I do have a ticking which is probably injector related, and came about after running through some cleaner. I think first another can of B12 is in order
rendyx
Buffalo, NY
93EmeraldMTX:
you didnt take the battery out did you? it might not have learned its idle yet.
Battery stayed connected. It hasn't done it again yet, so I wonder if it is a fuel related problem. I'm using some B12 in the gas tank now, so we'll see what that does.
jthomas68
Area 51
Pat,take a look at the tach when it won`t start.If it sits at 0,it`s the CPS.I`d run up there and help you out if i wasn`t leaving in 2 days.Can you make it another 3 weeks? :)
yamahaSHO
E85 whore
Arkansas
JT, I plan on making it out there next month as well. Maybe we can meet up??
<small>[ March 25, 2003, 05:10 PM: Message edited by: yamahaSHO ]</small>
rendyx
Buffalo, NY
jthomas68:
Actually... :D
Jason and I were thinking of doing some work the day before the May meet. If it's a Sunday, maybe we could do work on a Saturday?
