something i havent encounteredBefore,Have You?
matty
Southern Cali
was driving the other day in the 89, and car just went dead.coasted to the side opened the hood and the harness was starting to smoke.Well Come To Find Out,The Positive Cable That Goes From The BAttery To The Starter Sylonoid Grounded Out And Arked Where IT Was Rubbing The Frame.Got Another Cable And Everything Seems To Be As Good.I Was A Little Worried For A While
walser
new ulm MN
no i have never had that happen to me, i'd say your pretty lucky that it didnt ruin/burnout anything serious.
Lorenr
Vancouver,WA
Put it in the trunk
That is one of the many reasons I moved my battery to the trunk. I got most of what I needed at a U Pull It yard including a heavy duty, plastic, late model Ford battery tray.
There are a few good write ups (read these) here on the forum. But:
1. Mount the battery on the right side of the trunk over the rear axle.
2. Use a 21 foot (measure for sure) battery cable and attach it to the fender mounted solenoid. Use welding cable of the correct size and have them put the solenoid connection on for you.
3. Feed it along the drivers side door sill and up and out the opening for the unused automatic gear selector opening.
4. Take your time and you can make it look factory. It works really well.
Note: Because I had Aluminum Sub Frame Bushings, I didn't worry about a companion ground wire. Just grounded to the rear frame.
:omgsho:
