HotRodKid
mmmmm ... turbo
right now, alex has:
1) a vss that gives off a signal when rotated by hand
2)new wiring from the vss to the ecu
3) a new vss, i think this may even be his 3rd one
4) a different ECU in his car
now mind you, thats the entire system as far as the VSS is concerned, except for the pigtail for the vss
Our friend had a crazy thought... what if the tweecer is actually the problem? So i asked Alex when the VSS FIRST started acting up
"the problems started with teh FPS tranny when the tweecer was installed"
SOAB !
Obviously its not the FPS tranny's fault, cause it doesn't exist anymore
thoughts ?
SOAB !
thoughts ?
