Usmcsho01
Today I spent a total of 5-6 hours doing a complete spring detailing of my SHO, clayed, compounded, polished and waxed. Along with a complete clean inside as well.
IMG 2447 zps3anqnjbn
IMG 2451 zpsrgyqpsxs
IMG 2452 zps3ofezyqt
IMG 2443 zpsb23olagn
Also including a picture of the wheels, so you can see how the plasti dipped rims are holding up. :)
Looks great!
Sent from my XT1650 using Tapatalk
xFallenxCripplex
Attached some stickers a glossy screen protector and jms boost max just to be safe in warranty
And plastidip the extra chrome in front 9c215333a435404587834e520b1bd940655e1d3ac0a4c8a86446cf7665746c51D481e21aa0282e9a76e337afe1ec6249
Sent from my Nexus 6P using Tapatalk
7d3169531eb7a3348003725758dadb24D6b7ca21dd495bde4d85ba879f54bbc5
86540c5125d638e5208ce788665a13d1370b6ae5ecd7ea5a176414b9e3deccd7
marius883
Orlando, FL
Took a 300 mile road trip yesterday, averaged 24.6mpg. Maintained about 80-85mph the whole time, kind of disappointed. Is this normal gas mileage?
xFallenxCripplex
Ceramic break pads are pretty good I'd recommend red pads from ebc low dust quiet stop well. I was actually thinking has anyone had much issue warping their break pads from getting hot and then splashing In a puddle because sometimes you can't avoid that.
xFallenxCripplex
StealBlueSho
NA
Good to know guys, thanks!
I need to replace my brakes again, the ****** power stop rotors are warped and sound extremely sketchy from a high speed stop. I'm looking for good quiet brakes preferably a kit with rotors and pads.
What do you guys think about these?
http://www.rockauto.com/en/moreinfo.php?pk=8265816&cc=1445050&jnid=444&jpid=11
Power stop right into ccccuuurrrrbbbbbbb!!! On a for real note, same setup I have... sounds like a Mack Truck stopping inside my cabin from a high speed stop... no steering wheel shimmy though..
6500rpm
I had a fairly productive couple days. I cut the extra unused exhaust hanger off the rear frame with a sawsall (the one that sits across from the RDU plug), then changed the RDU **** out with Royal Purple. Today I had the well worn summer tires replaced with 255/45zr20 Continental DWS 06.
It does look like it filled in the void between the tire and wheel well slightly, but when I measured through the centerline on the wheel to the well opening they're exactly the same as the 245's.
I was hoping for a bit of a vehicle lift with the tire that I was going to play take away with lower springs. The bottom of my front lip spoiler is 5" from the ground, I'm not sure I want to lower it any more than that.
20170411 174932 zpsqt29dzvs
mrhighcaliber
Just upgrade to the 2013+ 14" rotors/calipers in the front. For less than 350$. And use semi metallic pads. Ceramics are low dust but need higher heat to create the same friction as a semi metallic. Couple that with the lower mass and smaller diameter of the stock 2010-2012 rotors, plus the high speed and weight of a sho and u have a recipe for warpage. I did my fronts last year and they're awesome. Have police spec pads and slotted StopTech rotors. I have the pads and rotors for the rear, Just need the calipers to install the rears.
Sent from my Nexus 6 using Tapatalk
StealBlueSho
NA
Yup, that is on my to do... saving the pennies though for a HPFP..... figured I would finish wearing out my brakes before replacing them.
Thanks for the advice though! I thought without the 2013+ brake booster the bigger rotors/calipers were not that much of an improvement..
mrhighcaliber
Driving the explorer sports at work, I notice less pedal travel and a firmer pedal feel compared to our 2010-12. Ours require a bit less effort, more travel and a more squishy feel. But as far as stopping power/ brake line pressure...I don't think there's any difference. Before the swap, at 140mph or higher, my stock brakes didn't do much after 3 seconds of standing on the pedal. After the swap, they will try to pin u to the steering wheel from 130 down to 0 without fade. Night day difference. That's just with fronts. Side note : the coming hpfp, what kind of hp gains are to be expected with this? Haven't seen any hard numbers /dyno runs for even the lms f150.
StealBlueSho
NA
So my guess is with the 30% increase in flow will allow me to run more ethanol and allow me to push more load without using the throttle closures to control load (which helps the fuel pressure dips)
If you have ever had a tuner setup a tune without throttle closures to control load it's pretty sweet... changes the whole character of the car...
So not having to worry about dips in fuel pressure and open throttle is worth the money to me...
mrhighcaliber
Ahhhhhh! Things are making sense. Those throttle closures to control power output underload. Evident by the waves observed in a dyno graph on one of the ecoboost vehicles. You filled in a blank for me. Thanks.
marius883
Orlando, FL
So just now, I was driving home from work, and I spotted a hellkitty charger on the highway. I of course pulled right up next to him, hoping we'd get off at the same exit. He pulls off at the same exit, and we end up at the red light, side by side!
I hold the brake and rev it up around 1800rpm, light turns green, and for a couple of seconds I'm winning, then the growling supercharged kitty flew by me as if I was standing still! :(
That was the moment I wish I was driving @bpd1151 's car haha! Either way, it was a blast! :eeeeeek:
beesbuild
