Small Hiccup in Engine Swap, Will 2010 Lincoln MKS Engine Plug and Play In the SHO?
BayAreaSHO
Bay Area, California
2011 Taurus sho, just making sure the Lincoln engine will plug right in before I order it, first engine the seller screwed us and sold the turbos off the engine before we could buy it and wouldnt lower the price of the original.
You have to check that the tone ring is the same. There should be a few swap posts with some similar info. Also poke around ecoboost forums. I haven't seen alot of swap posts so that stuff isn't easy recall. Shodded or someone might have better info.
BayAreaSHO
From everything I’m seeing it looks like it should be a plug and play fit, just wanted to double check. Thank you!
hosbaldosho
