SM105K's SHO BIBLE/BUILDS/LIFE
Here is the bright side. I will get some testing done probably early next week with new dragy numbers. That should hold you guys over for awhile.
I only drove the car a couple of hours before I took it back to Dyno Comp for a tune revision on Friday. However, the mid range really woke up. 845 ft lbs will do that. This is Dyno Comps first time tuning the Spool Pumps. They were only a PTG dealer, and they were willing to work with me. So I knew tune revisions would be on the docket because of a new product. The throttle tip in was pretty sensitive, and the car was long cranking. I guess some Spool pumps have a problem with pressure bleed off. Dyno Comp is in contact with Spool to figure out a solution.
Either way Dyno Comp will make it right. Also I am in the beginning of XC and Enduro season. I have a race every weekend from January 11 through Feb 8th. That is forcing me to drive the tow pig and throw my leg over a bike 5 days a week. So I have limited time to FAFO the Merc, so ironing out all of these issues is perfect timing.
Car is back. Dyno Comp was having an issue with fuel pressure bleed down. This was causing long cranking. Spool asked Dyno Comp to do a multitude of tests. I personally didn't realize that the fuel rails had to be removed and drilled ect. Even with great care, it seems that injector 8 got something stuck in it and hung it partially open. Dyno Comp replaced all of the injectors on that bank. The opposite side injectors seemed okay, but they still sent them out and had them professionally cleaned (even though they didn't have too). Dyno Comp has gone above and beyond with the tune, installation, and customer service. I 100% recommend them.
The Spool Pumps have seemed to be doing a great job. Fuel pressure is great across the board. I believe we have found the threshold of stock turbos coupled with 91 fuel at 720 hp and 846 tq to the tire. Not even mad about it.
Here are a couple more dragy pulls as the car sits currently.
FPCLDP ECU CPC TCU 91 OCT 0 60 dragy
Still struggling with the 0 to 60 times. The best I have gotten was 3.17. This one at 3.26 was in race mode, full stiff suspension, traction off, PS4's at recommended MB tire pressures. I did what @kponti said " I would activate racestart and launch the moment racestart flashes on the screen. Do not allow the car to build boost at all!!!" With almost 850 tq and 48 degree pavement this was the best I could get. I am sure that with more seat time, I will get this number down.
FPCLDP ECU CPC TCU 91 OCT 60 130
New PB from 60 to 130. 7.90 > 8.11. Believe this time is hampered by 91 octane fuel. I do have 5 gallons of 91 in the car right now, and I added 4 gallons of Sunoco 100 octane fuel. I will go out soon and rerun all of these tests to see if the car will pick up with the increase of octane like it seems the 93 octane cars do.
FPCLDP ECU CPC TCU 91 OCT 25 mile dragy
This is a PB for the car. Against the last 10.96 PB. Of course a 10.95 to a 10.96 doesn't seem like much. However the numbers are interesting.
10.96 sixty foot = 1.72 / 10.95 sixty foot = 1.83. This was .11 second slower. Every tenth off the sixty foot is roughly 2 tenths off the quarter. Following that pattern this pass could be a 10.7x if I can get the same sixty foot again.
10.96 330 ft = 4.64s / 10.95 330 ft = 4.72. Again .08 tenths slower.
10.96 1/8th mile = 7.08s @101.10 / 10.95 1/8th mile = 7.13 @ 102.40. Again .05 slower but 1.3 mph faster.
10.96 1/4 mile = 10.96 @127.43 / 10.95 1/4 mile = 10.95 @ 129.29. Faster by .01 seconds but 1.86 mph faster.
The 10.96 run had 794 ft tq which yielded a faster 1/8 mile and 671 hp which yielded a slower big end. The 10.95 had 846 ft tq which yielded a slower 1/8 mile (mechanical grip challenged), but 720 hp which yielded a faster big end.
Nope. It will get more octane first. Guys on 93 octane with the same mods are going similar 0 to 60 times, 7.20-7.40 second 60 to 130 runs, and running 10.60 to 10.70 quarter mile times @ 129-131 mph.
Then it will get a drag radial when I need new rear tires.
kryptto
South East, Florida
forget you folks on west coast get crapola 91
kryptto
South East, Florida
Yeah that’s super lame. I have a few stations by me that get 110 with zero E in the summer.
I found a sunoco buy its like 20 miles away has racing fuel gt 260. However with 93 I would prefer ethanol mix at this point with the hpfp. That gt 260 would help you folks for sure.
Went back out with a bit more octane. I chipped it down again.
FPCLDP ECU CPC TCU 91 OCT 319 0 to 60dragy
Bit by bit. Wheel spin wasn't as bad with a bit better throttle modulation.
FPCLDP ECU CPC TCU 91 OCT 790 60to130
I figured that it would pick up with more octane. Guess not.
FPCLDP ECU CPC TCU 91 OCT 1088 25mile
Sixty foot was a little better, which lead to a better quarter mile since performance was roughly the same. Just goes to prove how important the sixty foot for ET.
E63S Update - I went and spent more money again. This time for a AMR tune. I am not happy with the Dyno Comp tune for a couple of reasons. The trans tune itself has been really interesting and drivability isn't what I want. The shift between first and second is not cool. So I took it back, and they tweeked the tune. It drives great now. However, when I put the car in race mode and try to launch it....it falls on its face. I went from going 3.10 seconds 0 to 60 to pulling a 4.70. The car is a complete dog now. So cleary there is a correlation. Also the idle tune has never been correct. Being catless, it really stinks literally.
There has also been some things behind the scenes, with fuel rails and injectors, and overall I would call shop fatigue. Dyno Comp has done a great job throughout the process and made things right, but I just want a fresh start.
That being said, I am going to work with AMR for the next stage in the tune. Going to start with their Stage 2 (The German car owners and tuners refer to mods as stages) 91 octane tune and get that dialed in. Then we are going to see if I have enough in tank pump to have a dedicated E30 tune. That will make me a lot happier in the summer here in Phoenix. Also since we are remote tuning, the Comp Port tuning suite gives me the ability to datalog (more knowledge the better) and gives the tuner remote tuning ability.
Ideally I want the tuner to the level the tq curve and bring it max tq down into the mid 700's. There is a couple of reasons for this. First reason: wear and tear. Second reason: I believe it will launch better and harder because the tires aren't going to be hit with 840 lbs of tq off the rip. If I can get the car to sixty foot in the high 1.50's or the low 1.60's that is a 10.50 pass.
I also believe we are leaving HP on the table with a lack of timing. I want the E30 for the cooling properties and because ability to add more timing. I want the car to leave to leave hard, but have an amazing top event. I believe the Dyno Comp tune was the opposite. Good down low, and safer but mediocre on top. My car is down 3 to 4 mph on the big end against other stage 2 tuned e63s' and I believe that can be fixed with better fuel.
So yeah.....
kryptto
South East, Florida
So yeah.....
So unfortunate realities aside, I except nothing less from you - from every post I have read from the last 1 year+
I am actually enjoying the car and the troubles it gives me. Gives me something to keep reaching for. When I reach the top, I get bored, and when I get bored..... only bad things happens.
**** I might even start working on the Lexus again.
kryptto
South East, Florida
you will break the next barrier I am SURE of it
