SHOracer14
Me-0 Diffs-6
Well I just purchased a 93' MTX and I'm baffled as to a few problems left. I bought the car with the CE light on, and pretty horrible oil in the plug wells. So I pulled everything apart, replaced the valve cover and plug well seals replaced spark plugs, swapped the whole intake system from my white plus (clean and all sensors work), and then also replaced the 02 sensors and did the idle reset. It runs a million times better than it did but it still doesn't run like a SHO should. I no longer have any warning lights flashing so I dont believe there are any stored codes and the motor was pretty clean inside when I had the valve covers off so the oil had been changed on a regular basis. The thing just lacks down low power and isn't smooth in power delivery. When the secondaries kick in it feels almost normal but than starts dropping back off and takes foirever to climb RPM's. Now the only other things I can think of are plug wires and fuel pump. The fuel pump is pretty noisy but starts right up and seems to run fine. Any suggestions??
To put it into perspective I got beat by Speedy_91_SHO's winter car (red 91' plus) and I don't mean I got beat I mean I got demolished. I may have a hard time beating civics.
