Slo Sho
shomtx95
wilkesboro,N.C.
awesome build man, was it a stock block? how big of a shot of nitrous are you running, wet or dry?
MikeGSki
******* Out
Keller, TX
Stock internals 3.2, P600B Prcharger, 75 shot dry, 9psi ....I cracked a compression ring while learning to tune with the tweeker...oppps lesson learned. It was leaking oil before the dyno and racing the C6 was just helping it into the coffin.
MikeGSki
******* Out
Keller, TX
Have you pulled it apart yet?
Nope. I'm going to run a compression test this weekend just to see if it is the #6 piston. It was the only spark plug that looked alittle bit bad and it really didn't look that bad. And then take it out to the street races and call some people out until it blows, then tow it home. And if it still runs after saturday it will go to MSR and get beaten till it goes. And if that doesn't **** it a 150shot will :)
nik97
Mile high
I have a feeling there's more than 1. Hopefully they look like this
and not like this
But with all of that oil...
MikeGSki
******* Out
Keller, TX
Who knows. I'm just suprised it still running, doesn't make any noise, and has no smoke or oil coming out the exhaust. I'm going to get a big catch can and see what happens
nik97
Mile high
Yeah, my car ran great with 2 of the three pistons with broken lands but I only drove it for about a day before I tore it apart. Do what you want but the longer your car runs that way, the higher the risk of shit coming apart in the chamber and taking out your heads and cylinder walls.
MikeGSki
******* Out
Keller, TX
I'm going with a new block and everything
