AutoSHO:
What you are feeling is a condition known as "chatter". It happens when the flywheel isn't properly resurfaced, the disc is contaminated upon installation, or it has been abused/glazed. Typically this happens because the first thing people do with their new clutch is see how hard it grabs, which is the wrong thing to do. You must baby a new clutch for at least 500 miles after install before you can slowly get more aggressive with the engagement. There really isnt a fix for it aside from removing everything, resurfacing the flywheel, and repeating the break-in procedure, preferably with a new disc. Sometimes getting the disc warm (slipping it, say start in 2nd gear, rev the engine up a bit, and slip the clutch out, to try to clean it up) in an empty parking lot will help to get it to smooth out.
