white92mtx
Hey everyone, new to the forum as well as the sho scene. Bought a 92 about 2 weeks as my daily driver. Hoping somebody may be able to shed some light on my situation. The cars subframe bushings had been pulled out of the subframe causing the ignition control module to crack and disconnect itself when going into the driveway, shutting the car off, and driving me crazy in the process. I replaced the bushings as well as the i.c.m (used dielectric grease on back of module, and made sure the 4 bolts were tight) Car definately ran smoother....for about 30 seconds. Half way around the block it started bucking and popping. CEL came on, and tach started acting weird. Now from my research this seems like a no brainer....crank positioning sensor. I decided to do a tune up regardless. The next issue is that the spark plug wells were FULL of oil, and one of the wires was in half. I ordered v/c gaskets and spark plug wells, going to do new plugs again, and put my new wires on. Wasnt going to bother putting brand new wires in an oil bath. My question being, is there a possibility the current issues may be causing tach to fluctuate as it did? I know that the oil issues and bad wire are causing the rough running issue, but am praying that this is the only issue. Anybody's input is greatly appreciated. Tried giving all the info i could. Not really sure of the vehicles maintenence history, so unfortunately i dont know what has been replaced, and what has not. If you have read this far, Thank you! I am looking forward to getting it running well so i can start modifying!!!!-Ryan
