SHO wont fire.
KazMan
Upstate NY
This morning after starting my 92 SHO i came back outside after 5 mins or so to find it had stalled. It wouldnt start back up...I ran the codes to find 3 fuel pump fail codes. The pump however would spool up when i turned the key forward, has less than 10k on it, and appears to be building pressure when I check the check valve on the intake.
I pulled a sparkplug wire and had my wire turn the car over while i watched and I didnt see any spark or hear an arc. My 60k was done around 10k ago. Including waterpump CPS, CID, timing belt. Where else do I need to be looking?
slapnpop
Johnson City, TN, USA
Possibly the DIS module?
Autozone/advanced will check them for free. It's the grey electronic piece with a plug on either side, passenger's side of the intake.
skippie
Monroe , MI
Ah yes, this happened to me with one of my cars, although it was just something as simple as a bad alternator, so you might wanna check that too. just a suggestion.
