Couple of weeks ago my SHO would not start. I diagnosed the problem as a failed fuel pump. I could not prime the injectors when I turned the ignition. There was no fuel pressure at the intake.
I recently installed a new fuel pump. The injectors now prime when I turned the key. I checked the valve at the intake, and it would spit fuel with vigor. However, the engine would not start. It tuned over, but nothing.
I noticed that the cooling fan would run when I turned the key, but the ac was turned off. Normally the cooling fan only turns on when it is up to temperature, or the A/C is running.
So I figure that there is a short some where, or a module is dead.
Any ideas as to where to start looking?
Jose
Jose
