SHO WILL NOT START
SHOPLUS2NR
Idaho
My 91 SHO PLUS will not start. My fan and ac quit working along with no power getting to the fuel pump so I changed the starter relay and the relay control module. Now I've got the ac working and the fan but still don't have any power going to the fuel pump. Can anyone please help? I don't know whatelse to look for?
Machspeed
Former 1991+ owner
Santa Barbara, CA
Your not getting any power to the fuel pump. How do you know, its not making the that sound when you first turn the power on in your car? Maybe time to change the pump...
SHOPLUS2NR
Idaho
I just ran a KOEO test and came up with these faults: 96, 59. 96 fuel pump secondary circuit failure, and 59 is low speed fuel pump circuit failure. There is no pump noise before I try to start the car. Should I just get a new pump or is there something else I should check before changing it?
Slo-Sho
It wasn't me!
Crossroads, CNY
Ground the fuel pump circuit, so the pump runs continually. The result should help narrow your diagnosis.
TYSHO
Earth
Have you tried the switch in the trunk on the driver side? shrug
SHOPLUS2NR
Idaho
Sorry, I forgot to mention that I tested the switch and it worked like a champ. It killed the engine just like it should. I think I'm just gonna go with a new pump and see what happens. Anybody have any info on a good pump?
SHO--ripper
928 Euro
winsted,CT
I replaced my pump with one from advanced auto. It was OEM, but it really helped my 89. A lot of people go with the Walbro 190 LPH. Good luck and after you replace the pump you will love the way it drives again thumb
SHOPLUS2NR
Idaho
You are exactly right. I checked the fuse and it was burned all the way. Your the heat.. lol Thanks. Now any ideas on how I should go about fixing it?
