My 1993 3.2 SHO has been leaving me stranded after it warms up. The car runs great and just shuts off without notice. It will crank but not start. Sometimes I make multiple trips in a day with no problems. But when it does stall, it always takes a cool down of 30 to 45 minutes before it will restart. I am familiar with the water pump issue and how it can leak down onto the crankshaft sensor. But the water pump is not leaking and there are no fault codes stored. As of today this has happened to me four times. Each time there has been no faults stored. So far I have tried a new ignition control module and an used ignition coil. The last time it stalled I had time enough to check a few things. Using a fuel pressure gauge, i determined the fuel pressure was good. I checked the spark plugs and noticed that the was no spark to any of them. I also determined that I had 12 volts going into the coil pack. My thoughts are turning towards the PowerTrain Control Module. Does anyone know how to checkout a PCM using a multimeter Or have any ideas on other possible causes. Thanks for your help.
