Ok so I have began to pull the car apart. The engine and tranny came out through the top. Did not remove subframe. I am picking up new Tranny and Rod Shifter on Sunday. I also have a list of other parts that I am about to buy from SHOBrosGarage... Let me know If you think there is anything else I am missing or will need to compliment another part I am buying.
Service Parts:
3.0 Acc Belts (both)
Cam Seals
6 Spark Plugs
VSS
Cam Position Sensor
Crank Position Sensor
Coolant Temp Sensor
Idle Air Valve
Intake Gaskets
Oil Pressure Sensor
2 O2 Sensors
Fuel Filter
Spark Plug Wire set
Timing Belt
Valve Cover Gasket Set
Thermostat Kit
Reman Water Pump
Fun Stuff:
SHOBros Y pipe w/cats
Dynomax Cat-Back Exhaust
SHONUT Reinforced Motor Mounts
SHOBros Stage II Brake upgrade
Front Strut Bearings
KYB OE style Struts (front/rear)
SHO Intrax Springs (1.5'' drop)
SO that is everything. I am also going to replace the front ball joints.
I have already done the rod bearings. And Clutch in the last 3k miles.
I also plan on cleaning all the rust spots out and doing body work and having the car sprayed the factory Black.
What does everyone think?
Service Parts:
Cam Seals
6 Spark Plugs
VSS
Cam Position Sensor
Coolant Temp Sensor
Idle Air Valve
Intake Gaskets
Oil Pressure Sensor
2 O2 Sensors
Fuel Filter
Spark Plug Wire set
Timing Belt
Thermostat Kit
Reman Water Pump
Fun Stuff:
