SHO ford probe project
probe_racer
california
Purty! :omgsho:
This is inspirational. Reminds me why I've been willing to struggle thru so much to get mine running. Curious - what kind of paint did you use?
Keep at it.
Thanks :wave:
I used high temp engine primer and enamel from duplicolor for the engine and intake and then high temp clear from duplicolor as well, the color for the intake is just RED. and the one for the engine is NEW FORD GRAY.
probe_racer
california
hmmmm I just noticed i have not posted pics of engine bay modifications and engine in probe on this thread.
soooo :munch:
engine bay painted Ford gray
P1160618 zpse14be68d
notched frame passenger side
P1160617 zps0f7ec487
P1160616 zps03a2f14b
drivers side engine bay not needed to be modified
P1160615 zps40a01233
engine in car (intake removed to avoid scratching the **** out of it) engine/mount can be seen modified a little... I might redo it so it looks more factory like. :angelnot:
:omgsho:
P1160619 zps7e71371b
P1160620 zps0c12510f
pic of why notch was needed.
P1160621 zpsffcc8356
power steering pump will not fit... unless i find a smaller power steering pulley, im not worried about overdriving pump since the stock probe one was smaller but it was much wider..... maybe electric power steering from MR2?
comments always welcomed.
:thankyou:
probe_racer
california
it's a probe, do you really need power steering?
not being a smart ass, serious question.
no problem :)
Yes, i really do now.
First issue is I have wide sticky tires on the car, and i driven it without power steering, and man it was a pain in the ass to turn. The second and more relevant issue now is that I have a bad left shoulder, I had two rotator cuff surgeries and I have no full range of motion or strength on that arm. :frown:
probe_racer
california
here are some pics of engine mounted, the front mount on the transmission will be redone so that there is no gap.
the top transmission mount will have the slot where bolt goes filled with welds to limit movement.
P1160639 zps4c0f3404
P1160638 zpsccff903e
this engine mount was totally new in order to have engine mount properly and give clearance for radiator hose.
P1160637 zps28d6fcd1
the rear engine one next to driveshaft will be probably welded to frame instead of just bolted. I used a stock ford probe transmission mount (like the one i cut at front of transmission)
P1160643 zps818104f7
I had to modify the stock mounts in order to move everything about 1.5 inches in order for engine to fit and still be able to use the stock axles.
i used 7/16 inch and 1/2 inch steel in order to create custom brackets.
now i need to modify the downpipe at the front a little bit in order for it to clear the subframe on the passenger side and not to stick out way too low and be exposed to road debris.
BTW the starter is the stock one from the Probe.
will post more pics of progress soon.
:munch:
does anyone know the strength of the Probe tranny? Is it the same as the SHO but different housings, or is it lighter?
probe_racer
california
And here is the wiring harnesses such a huge headache....
engine harness had to be made longer, spliced, had to remove/add wires. replace ccrm with individual relays.... a huge pain in the ass. Notice ccrm connector is gone and has been replaced by a series of relays can be seen on top right of pic.
P1160647 zpsd475906c
body/main harness had to add connectors, splice wires, etc...
P1160646 zps97151706
oh probe transmission will hold up over 300 hp and 300lb of torque a few probe owners have run like this with no issues with the F2T and FE3 engine and this tranny.
probe_racer
california
and the probe tranny fit the sho engine ?
yes..... there is the need of making a small notch on the probe transmission to clear the rear main seal cover of the sho engine, that is the only modification so it bolts up to the sho engine.
Shovert
ky
Nice job. Might want to put some tape over the intake passages. Sure would be a nightmare to drop something in the engine. Maurice
probe_racer
california
I use a big plastic trashbag to cover the intake ports on the heads and on top of that i put a big towel with a big piece of wood so nothing goes in. I wanted the engine to look "nice" for the pics.. but thanks for heads up.
The probe trannies should not be that hard to find, even mazda still sells replacement parts for them.
I will post more progress as soon as i get more additional stuff done.
:wave:
Shovert
ky
Just concern. I have seen that simple mistake cause alot of problems. I use body shop green tape. Maurice
probe_racer
california
no problem, i appreciate the feedback. Once i had i freaking mouse move in on an engine block and made its nest on the intake manifold that had no throttle body, engine was not covered but it was inside garage sooo annoying every since i use the big white trash bags to cover engines that are stored and use the towel method when working on exposed intakes.
220ksho
Gen I bias
Oxford (White), MI
Looks great. Keep it going!
I just want to add that the front engine mount bracket (cast piece) will break without the a/c compressor attached, IME. The compressor housing is a structural component to the mounting bracket. Either fab up a reinforcement, or use the comp housing.
probe_racer
california
weekly update.. nothing done to car because another car (minivan) in the house broke and Im on the process of fixing it... hate minivans sooo much they are a pain in the butt to fix.
Did add a wire to run the extra oil pressure switch up to dashboard.
will post pics of redone front transmission mount and wiring by weekend or so..
platoribs
Live to Drive
Plat0ribs House of SHO,il
Great thread, who'd thunk way back in 05-12-2010, this would have reached this point?
Kudo's for sticking with it. Looking forward to seeing this beast finished!
:salute:
probe_racer
california
and finally pics of updated/revised/modified mounts:
(I kinda screwed up the look of the weld at the end by putting extra weld on top of good welds, in a wild eye attempt to make it stronger) :laugh_ti:
Pics not to high quality since they came from phone.
On this mount i used two stock ford probe transmission mounts and welded them offset.
IMAG0625 zpsb1573c58
And this one I re-drilled and welded the bolt slots to compensate for powertrain being moved and to limit amount of movement too.
IMAG0627 zpsea9be7d1
will be posting some updates more often I hope.
