SHO bucking!
cjg92sho
Pennsylvania
SHOtimer said:
Those plugs and wires will not work well with the SHO motor. You should replace them with Motorcraft parts.
Who makes the plugs for Motorcraft???? I always thought is was Autolite.
bcdescd22
Louisville,KY
OK now when it was idleing every 2 or 3 min the motor cuts out briefly? Still no codes and the following has been replaced,plug,wires,IAC,CPS,CID,fuel filter and the MAF sensor has been cleaned. Any suggestions?
shonole
One Star!
Thomasville, GA
When we did my 60k we used Motorcraft plugs and Borg/Warner wires, and it's running SMOOTH so far! :hail:
:knockonwood:
Huntervf
Bored now
Back in Michigan ... again.
No, plugs should be fine. If it were still idling rough that would be one thing, but a stumble every few minutes sounds like a separate problem. Sounds like you've replaced most of the trouble items already :shrug: When you pull codes does the computer do anything strange? I had a 95 ATX that had weird idling problems and when I'd pull codes the computer acted a little different than normal... sometimes it wouldn't run a KOER test, and it would never run a goose test. I was suspicious that the computer was bad, got a replacement and voilla, all problems solved.
It doesn't sound like you have a comp problem, but just the same be aware of how it acts when pulling codes. Does it go through all the modes ok?
bcdescd22
Louisville,KY
Yea when I check the codes everything is fine. The idle seems fine you can tell its surges very little but it wont be perfect.
bcdescd22
Louisville,KY
I did see a couple of lil black specs in the coil pack where u plug them in? I guess next step is a coil pack?
shobroooo
