CobesSHO
OK, I had some shifting problems shorting after buying the car, 1-2 shift. Looked at the rod shifter and noticed it was very sloppy at the shifter/tranny fork union. Beefed-up the the rod shifter portion by drilling it out to 1/2" and adding 1/2" brass bushings and new 3/8" bolt. Shifting got much better but still wasn't where it needed to be. Next I changed out the tranny fluid and the shifting got much, much better, but I had a leaking axle seal that needed replaced. So I replaced the axle seal, added more fluid and I also repaired the bad front motor mount. Shifting was awesome, amazing how much better everything was. Now today I drove the car to work and can't hardly engage into any gears without struggling. So when I got home I loosened the rod shift support bolt and rod shifter/tranny fork bolt, thinking that it's possibly a alignment problem since the last time I tightened these was when the front motor mount was shot. I haven't driven the car after this but I am assuming it's still going to be bad, but hoping otherwise.
Any ideas on what could be wrong? Is it a bad throwout bearing? I was told the clutch is realtively new (less than 600 miles) and it seems strong. Is there something else I should be looking at because it's really wierd how it went from shifting great, sitting overnight, to shifting terrible.
