SHIFTING PROBLEM
FASTSHOMTX92
NEW YORK
Whats up guys, my 92 sho has a problem, she will not go into first gear unless the car is off, than it is ruff going into 2nd 3rd & 4th also 5th, also inorder for me to put it into reverse the car has to be off or elts it will just grind, the only way it will go into first gear with the car on is if the car is rolling and i give it a little gas, i was thinking that it was the slave cylinder but this guy told me it was the rachet on the cluch petal, any ideas
SHOMurph
Ford B@stard
Arlington, TX
I recently had this problem. Many will say instantly its the clutch (which it might be.) First check the clutch pedal. The slack adjustment on the clutch pedal is plastic and will wear. Mine was worn and would not keep the cable properly set for clutch disengagement.
Texan Tony put a mod to fix the clutch pedal quadarent so that the cable is fix. You wont' have the adjustabilty which is a minor thing but you will be able to shift properly.
email me at [email protected] and I'll forward it to Tony to tell you how to fix.
It may be a clutch/throw out bearing problem but this is an easier fix to try first.
<small>[ August 13, 2003, 11:03 AM: Message edited by: SHOMurph ]</small>
Zap
West Bend, Wisconsin
Is there any specific way to test other than these symptoms that would indicate that the slack adjustment part of the clutch pedal is having trouble? I'm just curious because in the first 150 or so miles on the '94 the new clutch has yet to require any adjustment (it doesn't click when pulling up). However it shifts very nicely, so maybe there isn't anything to worry about.
SHOMurph
Ford B@stard
Arlington, TX
Zap:
If it shifts good then no worries.
If the cable tension is found to be properly set, then your pressure plate and throwout bearing interface is worn and will require replacement. This is basically a "new clutch" and should include the friction disk, pressure plate and throwout bearing and resurfaced flywheel. Other services possible with the transaxle out of the car are new rear main seal, new shift shaft bushings, new transaxle seals and even new synchronizer blocking rings. My story posted in the Forum with pictures here and here.
