HoustinoJillian
name's JUSTIN
ok here's the scenario: 95 mtx, and its very hard to get into reverse... to get into first its a good shove and then it clicks in, but its not easy, to get into reverse its almost impossible, the only way to do it without grinding the gears and not ging in is if the car is at a dead stop(well duh on that part) i put it in first, neutral, clutch out, clutch in, first, reverse. anything different and it usually doesn't go, even if the car is started from cold after being parked in first, anything i can do to fix this?
