Shifter movement - swaybar upside down
strykr14
Michigan
All,
I had posted that my shifter was rocking back and forth when I went over bumps. Couple guys said my swaybar was on upside down. Can anyone tell if that's the case from the pictured below?
DSCF2412
DSCF2414
Racer X
SHO Pilot, Retired
Connecticut
We'd need to see the bar where it crosses in front of the steering rack, but to save you the trouble, the center of the bar should be above the center line of the sway bar brackets. If it hangs below, it's upside down.
kevinspann
Don't take my advice.
Richmond VA
Also - it doesn't hit the shifter rod when the suspension is unloaded (barely). Mine had rub marks on it - but it was painted silver, so easy to see.
strykr14
Michigan
I did this too. There is even a support group here for this problem. You will have to drop the rear of the subframe.
Sigh,
I thought someone would say that. ok, so, drop the subframe at the rear. Can I do that w/o affecting the alignment? I just had it aligned.
strykr14
Michigan
ok, I looked under the car. I can see rub marks on the sway bar where it's hitting the shifter. The sway bar angles down as it crosses over the shifter. Assuming it should be angling up. Ergo, it's upside down. There's a support group? Did a thread search, nothing.
Racer X
SHO Pilot, Retired
Connecticut
Drop the rear of the subframe, support with a jack. If you don't loosen the front, alignment won't be affected.
Racer X
SHO Pilot, Retired
Connecticut
Not unless you have AlSFB's.
Granted, you're not letting the whole thing drop to the ground, you're only lowering the subframe 2" or 3" to unbolt the sway brackets and pull the bar out the side.
land pilot
