ok, how hard is it to remove?
I did this too. There is even a support group here for this problem. You will have to drop the rear of the subframe.
Drop the rear of the subframe, support with a jack. If you don't loosen the front, alignment won't be affected.ok, I looked under the car. I can see rub marks on the sway bar where it's hitting the shifter. The sway bar angles down as it crosses over the shifter. Assuming it should be angling up. Ergo, it's upside down. There's a support group? Did a thread search, nothing.
