x-tream said:At idle the oil light is on and there is a bit of a knock. all fluids are good and it goes away at 1000rpm. only happens when warm and below 1000rpm. anyideas or is a for sale sign a good investment?
BlownByU said:Do them ASAP, you will cause damage to the crank and the engine if you let it go any longer I'd suspect. Mine started to go and went to the point that the engine seized very fast. If you're uncle is gonna do it, tow it do not drive the car or you'll be doing a 3.2 swap sooner than you think.![]()
x-tream said:Waht is the big difference between a MTX vs. ATX would the problem not be the same.
For those who have done this, how long has it taken you, or how long has it taken a shop to do it. I am capable of doing it my self but just wondering if it is worth the head ache.
