says it is running hot
dunndt
North Carolina
my sho temperature guage says it is running very hot but the heat isn't even hot yet but a few minuits more and my heat will work so i know that my car is not running hot. i am guessing that it needs a thermostat what is it.
That would be the temperature sender for the dashboard gauge, not the thermostat.
twr
whoohoo
half-way there, I think.
sdpatt:
Scott,
Correct me if I'm wrong. But would a stuck closed thermostat have the same symptoms?? Overheating and no heat in the car??
dunndt
North Carolina
well the fan on my radiator is on almost constantly right now and the guage shoots up within 5 minuits of having the car on it will be at the red line this is just sitting there
<small>[ November 12, 2002, 01:06 PM: Message edited by: dunndt ]</small>
the thermostat being stuck closed would give you plenty of heat assuming there is enough coolant in the system.
dunndt
North Carolina
what is the estimated cost of a repair for this
would it be the temperature sender or thermostat, how do i check
<small>[ November 12, 2002, 01:14 PM: Message edited by: dunndt ]</small>
BeatDaSHO
Hatboro, Pennsylvania
just replace both. the thermostat is the 192 degree motorcraft one because they dont' sell the 180 degree for the MTX anymore. The sender is only like 6 bucks. Coolant is about 5 bucks a gallon so it looks like you will be spending a whole 30 bucks. not too bad.
Greg
aleksander j
sho *******
norway
had the same problem..
but one day it wouldn`t work at all..
it was the sender temp 11b13j11
