SARC module
blownatx95
Minnesho on an alternate user name
cheeseville
Where is the SARC module located on the gen III? i'm picking up a ZF rack from a cam failure car tomorrow and I might as well grab the module as well in case i decide to hook up the servotronic. is it the little grey box under the dash that looks like the gen II VAPS module?
Silvapain
Limestone, IL
More specifically it's on the front side of the passenger wheelwell. Easiest way to get to it is to remove the back seat.
Funmart6
my name is mud
Auburn, Alabama
Hey Silvapain, which of your cars is quicker/faster, the SHO or the GTP?
GTP is a supercharged 3.8 right?
Silvapain
Limestone, IL
From a dig the GTP (Eaton M90 supercharged 3.8L) destroys the SHO - no contest. The SHO does seem to accelerate 100-120+ better though. The GTP is factory limited to ~120MPH.
blownatx95
cheeseville
I did grab the connectors. they are giving me the pressure line , and i got the rack to colum steering linkage and the rubber boots on the firewall. now does anyone have the connector pinout for the SARC (SRCM) module? I have a subscription to alldata pro but it dosen't show that module for some reason. From what i've researched before I need a power, ground, vss input, and servotronic output for this to work. i'll just ignore all the ride height circuits.
Silvapain
Limestone, IL
Without the ride height sensors the SARC module will keep the struts in firm mode all the time, but not reduce PS assist.
blownatx95
cheeseville
what is the sensor power and ground? I assume this is for the ride height sensors? i'm removing the terminals I don't need for the servotronic.
