SAI disable.
claypool72
Ohio
Is there a way to turn off check engine light due to the meaningless $140 impossible to get to relay, without a tuner. I'm a ******* so sorry for the question. Thanks.
kevinspann
Don't take my advice.
Richmond VA
I think you would have to buy an SCT handheld tuner, and a tune to delete it.
My_Silver_SHO
Reading, PA
I really struggled to turn mine off. After replacing the relay, buying a tuner, the fix was running another power lead. I wish I ran the new power lead before buying the tuner.
claypool72
Ohio
I had a new harness put. Mechanic said he heard the wine when he fired it up. But check engine light came back on a few days later and have sai code. Most likely the relay. Just don't want to spend 140. Really just want light off. Kinda like I did with the false low coolant I unplugged it.
My_Silver_SHO
Reading, PA
I have a couple relays from my ordeal...I can send you a good used one for $25 shipped.
claypool72
Ohio
Money sent. Hope it's not the pump itself. Also hope install isn't too bad. Anyone and tips and tricks for easy install. Please no sub frame dropping. Thanks
