Flintstone Chaz
Hi All,
I'm doing a RWD swap into a 68 Datsun Roadster. It is a long slow project but I'm having fun dealing with the various issues and challenges. Mr. 914 SHP has encouraged me to post a build thread and I may do that one of these days....
Anyway, the question of the day deals with an out of the box idea for dealing with the rear thermostat and cooling outlet challenge. I'vegot the engine shoved way back and it is sung up against the firewall. I've removed the DIS and mount and inverted the manifold crosstube and have the whole rear of the engine back under a shelf across the rear of the engine compartment.
I can't go back any more in the center of the firewall without intruding into the space inside occupied by the stock heater. I guess that too is negotiable but I wanted to explore another idea. I've never found anything on the net about it and if it has been discussed previously please forgive...
First, let me make sure I under stand the stock cooling layout: There are basically two coolant loops. One is from the suction side of the water pump, through the pump, into the transfer tube, into the heads then block and back to the suction side of the pump via an outlet in the front of the block. The second loop is via the lower radiator hose to the suction side of the pump, through the pump to the transfer tube, out the thermostat (when warm of course) to the upper radiator hose, through the radiator and back to the lower hose. Do I have that correct?
The "engine cooling loop" is always active and circulating. When the coolant is not up to temperature and the thermostat is still closed this is the only actively circulating loop. However, when the coolant reaches operating temperature, the flow from the transfer tube splits at the back of the engine and part of it goes through the engine loop and part through the radiator loop. Again, please let me know if I've missed anything. Obviously there are a few extra paths through the engine cooling loop such as the heater, manifold ans oil cooler loops but I'm including them in the engine loop.
So, the only common path the two loops have is from the suction side of the pump through the pump and transfer tune to the distribution spider at the rear of the engine. The relative flow balance or flow split between the two loops is a function of the relative restriction in the loops. The resistance in the radiator/cooling loop is in fact variable and is a function of how wide open the thermostat is as controlled by coolant temperature.
What might the impact or concern be if I were to block off the rear outlet and instead modify the pump housing or front of the transfer tube to allow the thermostat and outlet to sit at the front of the valley and exit forward?
The pressure in the cooling system will be higher on the outlet side of the pump and lower on the suction side. That is a function of restriction in the two loops. However, it seems to me that it makes little difference whether I split off the cooling loop at the front of the transfer tube or the rear. I don't see that it would have any appreciable effect on the flowthrough either loop. Seems like the flow out the thermostat and through the cooling loop would still be a function of the thermostat just as it is at the rear.
It is not a simple problem to accomplish the modification to the pump housing, or alternately, a create a thermostat housing that could pick up from the transfer tube but if successful it would cleanly resolve the rear outlet issue and put the thermostat and outlet up on the front of the engine.
There is space in the valley to accomplish this modification and the outlet would not be close to the timing belts. I don't have all the brackets and belts on my 3.2 so I can't verify that a center outlet doesn't have a belt clearance issue with all accessories in place. It would not be an issue on my application but I think the alternator will be the only accessory on my
If there was a concern that the thermostat when closed was a short way down a "dead" flowpath I would think that could be resolved by putting the outlet tube for the manifold heat loop at the front of that housing thereby making sure warm coolant could reach the back of the thermostat in a timely manner.
Thoughts?
Thoughts?
but a more elegant solution for the rear outlet would sure be a better option.
