runner control solenoid
benjammin
washington st.
Wouldnt a failed solenoid throw a code?...Im asking because ive isolated that as the problem with my secondaries staying open.
benjammin
washington st.
Im asking because I know that is my problem, but Ive tried another solenoid from a junk sho and that didnt work either. Im not gettin any codes from it though. Something screwy with my computer?
benjammin
washington st.
the hose from the TEE to the top ****** on the solenoid, hose from the bottom ****** on the solenoid to the bottom ****** on the accumulator...correct?
SHOMON
95 MTX
MEDWAY MASS.
Then from the middle ****** on the canister to the intake Yup. Maybe the canister is cracked?
benjammin
washington st.
nope...it works good. I bypassed the solenoid and canister...secondaries closed up. I bypassed just the solenoid...secondaries closed up. Put the solenoid back into the line...secondaries wont close. No codes at all.
I know the CEL works. Is there a relay for the solenoid?
SHOMON
95 MTX
MEDWAY MASS.
Sorry maybe someone else will chime in. In my car I had the 551 code and replaced the wrong part. Then I figured it out. My friend at Ford says the runner control is also the
4WD accuator for an explorer.
32sho
texas
You can check for 10 volts or more going to the connector from the contact of the red wire (key on-engine off) . Voltage is supplied from pin 24 of the constant control relay module. The ground is supplied by the PCM . Check for a ground with the key in the off position.
Devin
3.Slow
Pacific Northwest
FYI: you can't manually close the secondaries through the solenoid with the car off.
benjammin
washington st.
I checked continuity. I have no power at the connector to the solenoid. The wire runs through another harness, then into a little black box on the firewall. No power there either. Im guessing it runs down to the PCM?
32sho
texas
If you can take a small probe and pierce the two yellow wires coming from the CCRM (they are the only two yellow wires on the CCRM) you should have appox. 12 volts. Also do the same on the red wire close to the connector of the solenoid. I know you already checked the contact of the red wire, but I want you to check the wire going into the contact. I had the same problem not long ago and I found that I had a bad connection between the contact and the wire.
32sho
texas
I gave out some bad info above. I told you to check two Yellow wires for voltage. I meant the for you to check the Red wire from pin 24 of the CCRM. Sorry.
