All,
I have a 95 MTX 3.2
there is a rough idle after warm up and when I goose the throttle it will rumble like it is starved for air or fuel and will stall. If I gradually increase the throttle it will rev up just fine.
Once going it will go great and the secondry's open when they are supposed to.
I am getting codes 114, 157 and 542 for the key on engine off
116 for key on enginer running
I get 9 on the cyl balance test
I have replaced plugs and wires, cam position sensor, fuel filter
I have swapped a DIS and MAF and get the same thing. When i unplug the MAF there is no noticable difference
I took off the Idle air bypass valve and sprayed it with MAF cleaner and when I unplug the IAB the car stalls
I have tried spraying the vacume lines with carb cleaner and get nothing.
It was running fine before I put it away for the winter and this is new behavior as I am getting it out for the spring.
I have searched the forum and my candidates are:
1. The IAB is just bad and cleaning it was not enough and it needs to be replaced
2. Throttle position sensor
3. Coil?
4. Fuel Pump?
Any hlep would be appreciated.
I have a 95 MTX 3.2
3. Coil?
4. Fuel Pump?
