Rod Knock
SHOMON
95 MTX
MEDWAY MASS.
Hey Guys So I Went To Get Coffe This Morning And When I Started The Sho She Was A Knockin Which Really Blows!
I mean i have heard a little knock in the witer on really cold startup but for like 2 seconds and now its at like 2K rpm all the time the oil pressure light is not on so maybe thats a good sign and the oil was down 1/2 quart which in my car is normal
Anyways The Real Question I Have Is Do You Guys Think Just Changing The Bearings Is A Waste Without Having The Crank Ground And Putting In Undersized I Know If Its Within Spec Im Cool But Before More Drastic Measures Are Takin Like Getting A New Sho Which Right Now I Really Cant Aford I Can Do The Work Myself With Maybe Some Prof. Guidance So Thats Not That Bad But I Have Never Done It Before Just Put In Your 2 Cents And Let Me Know Oh Yeah The Car Just Turned 170k 95 Auto
Thanks Tim
"edit" after closer inspection i think it may be the timing belt slapping the cover
yamahaSHO
E85 whore
Arkansas
Longest Run-On Sentence Evarrr!!!
If You Spun A Bearing, You Need A New Crank Or A Refurbished Crank And You Need A New Rod.
