Ring job?
Devin
3.Slow
Pacific Northwest
I'm burning a bunch of oil. No real puddles, although I definitely have built up dirt/oil under the engine, and I know the oil level sensor gasket is leaking a bit... but I am putting in about a quart every 500 miles or so. I park in gravel, but I don't seem to leave puddles. To me it seems like rings. What are the other options? Is there a way I can tell?
zoomlater
Seattle, WA
any burning oil smell? any bluish smoke out the tail pipe? Have you gone under to look if its burning off on the cats. one of my cars used a quart every 1000 miles
Do you park in the same spot every day? If so you can put some cardboard uner the usual place and see if you are leaking to the ground.
I have seen alot of people use marvel mystery oil and I know there is a GM piston and ring cleaner. Seafoam also. I haven't seen anyone do this in a long time on a vehicle so I don't remember procedure other than soak and change out the oil when you're done. Maybe remove from piston/cylinder top first? I forget. Maybe some in tank additive could work. I think Nimz used to use atf fluid. I've seen more use MM oil but that's just backyard stuff a long time ago.
Irish Pride
Irish Inside
MusicCityUSA
Switch to Motorcraft synthetic blend oil. I've heard good stories about it being good at freeing stuck rings.
About 100 miles before your next oil change put a quart of ATF in the crankcase. The detergents in ATF can sometimes help too. The ATF will clean out any sludge that you might have in the engine.
-Chad
ATF has decent detergents and that is part of the reason why you can get tranny failure if you change fluid after it's been in there unchanged for a long time. I think it frees up stuff that was stuck in places and the new atf detergents free it back up into circulation.
I've heard of people using berryman's for rings too.
TankII
Bolton, CT
Sure it isn't exhaust valve seals? That is what I think is happening to mine, since it only smokes after sitting. Though if I am really ******* it, I see smoke when shifting above 7K
Devin
3.Slow
Pacific Northwest
How much oil are you losing?
TankII
Bolton, CT
I am burning about 6 quarts per 3,000 miles.
The car 'hydrolocks' at times after being run hard, taking a second attempt to start it.
Good chance it is stuck rings from what you describe. I have seen these engines with the exhaust valve stem seals totally gone and they didn't use that much oil (I think because of how the shim holders fit down over the top of the valve stem). I have had really good luck with Motorcraft semi-synthetic oil freeing up stuck rings, so I recommend trying that first.
Devin
3.Slow
Pacific Northwest
I am getting some smoke in the morning. But I also get some while at stop lights. It is very possible I have leaking valves, stuck rings and various block leaks.
Devin
3.Slow
Pacific Northwest
