Results in on current tranny failure!
somedude_001
Western NY
just got word that a spider gear from the diff went missing. WTF something different each time. I will go get pics in a couple days.
:swing:
somedude_001
Western NY
I should clarify. This is for me ATX not my MTX as my MTX does not have diff pins anymore due to a recent upgrade.
SHO_DOODmorrris
Owner & Fanatic
Alberta
upgrade as in removal by a fast spinning motion or by replacing with a more superior diff?
SHO_DOODmorrris
Owner & Fanatic
Alberta
well as soon as my Turbo build is done i will be posting a vid of me testing out my new welded diff... one wheel peel ftl. w/e it will be a cool way to burn off my old tires :p
gmail
Well-Known Member
sunbury pa
it takes a lot to get motivated to work on this thing. It sure does need a lot of TLC after 3 years of letting it build up.
too bad your not closer id give ya motivation :evilgrin:
glad to see things are finally going on again.. hoping some day i get to actually get a ride in a turbo atx.
hoping to see you at carlise this year?
somedude_001
Western NY
I will get pics of the damage from the old tranny tomorrow but I do have pics of the freshly painted new one.
Shoman594
Moderator
Lockport, IL
That work area looks like mine when the SHO is under heavy construction. When I go out there it looks like a war zone and its hard to get stared working again! After I take some time to clean up its a lot easier to get started :)
Any way you need to get this bad boy back on the road. I believe this car can change some minds on going fast with an atx.
I used to be the BIGGEST champion of all things Manual transmission. Heck I built the first V8 MTX. But if you really look at the FAST cars out there ATX is the way to go. Your car proves that.
somedude_001
Western NY
thanks. I just hope this one will last me a while. i'm sick of replacing these.
edit: I will be at the convention clicking off 12's on street tires at 10psi... so yes if you want to have useable power ATX is the way to go.
HotRodKid
mmmmm ... turbo
Western NY
see..... i TOLD you that throwing pennies in your transmission and wishing it would stay together would bite you in the ass !
DieselDan
NC
As I like to say at the shop... Its fine, thats normal just put it back together. Nothing wrong lol
