Replacing valve cover gaskets
bubbs609
Texas
I may just order thru SHOSource then. You have a woodruff key as well?
bubbs609
Texas
question. the 16 round hex screws that are on the valve covers....each of those have rubber grommets. would it be a good idea to replace those as well as all of the gaskets? I took them all off last night and degreased the covers and the bolts and was wondering about those black rubber pieces.
Fordlover96
Virginia
When I did the same job, I just cleaned up the grommets and put some black rtv on them when I installed them back onto the valve cover. They haven't leaked yet...
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
We do carry those at SHO Source.
If yours leak it would be good to replace. If not then it would be preventative maintenance.
bubbs609
Texas
I think im going to save $70 and just clean them up really good and add some RTV on them. Im on a pretty tight budget at the moment. I just want her to drive again!!
bubbs609
Texas
Also, should i clean up the bolts really good? Like, degrease the bolts and get everything all nice and shiny?
Fordlover96
Virginia
Why not? Lol. I just cleaned the grease off with some simplegreen and they shined like fine China.
bubbs609
Texas
That's what I'm gonna do. After I'm done with everything, I want to be able to eat off this engine
bubbs609
Texas
Since all the bolts are the same, I don't need to put them back in the same order they came out right?
Fordlover96
Virginia
As for the question about the bolts, iirc, all the bolts are the same, other than the 2 small bolts on the drivers side of each valve cover. You physically can't mix them up so no worries.
Just be careful when you reinstall as the bolts are very soft aluminum and tend to shear off if you try and tighten them too much.
LOUDSHO92
Sponsoring Vendor
Install the 2 small ones first. Also use just a hex key to install. It is easy to strip out.
poffffd
