Replacing valve cover gaskets and spark plug tube seals....
JoeHoe_SHO
SHOPUKE
Rochester NY
Alrighty, I have little experience working on SHOs, aside from waterpumps, breaks, belts and removing cams....How hard is it to replace valve cover gaskets and spark plug tube seals. SHOTimes didn't have a section (that I saw atleast) on how to do this. Any help would be....helpful :p
SHOnuff93
Dublin, Ca
remove the intake, remove the valve covers, take off old gaskets and tube seals, press in new seals, replace gaskets, bolt it back up, drink beer and enjoy a job well done
Mr Anonymous
Tire Wall
There's a 'search' link in the upper-right-hand section of the forum pages that will help you find the information you're looking for...
SW SHO
Boss Man
Santa Fe, NM
Have you ever worked on a V8, or at least seen a car show like hotrod tv? It's basically the same thing except all the work taking off the intake runners (which only the real time constraint) Mark the parts you remove for replacement or better yet take a couple of pictures (closups) in any area you see a bunch of disconnects.
Some have debated sealing the plug gaskets with Black RTV for good measure. I thinks it a matter of preference. I did it after reading such debates and watching the 60K video from CincySHO. I too had my doubts about doing it. Honestly, cleaning the IAB by itself was more time trouble... :D That pesky bottom bolt:D
Keep the floor clean, you bound to drop a bolt or two.. otherwise it's about has simple as Shonuff93 said.
<small>[ March 20, 2003, 11:55 PM: Message edited by: SW SHO ]</small>
RStalveyARFF
too many shos
Georgetown, MA
use ultra gray RTV. Superior resistance to oil.
<small>[ March 24, 2003, 05:44 PM: Message edited by: SHO91MTX ]</small>
JoeHoe_SHO
SHOPUKE
Rochester NY
Thanks guys!!! I won't be attempting this for a while. Need some cash first....good weather is always a good thing! Thanks again! thumbs_u
ribeye2065
