KentuckySHOoff
I am going to take my intake off to clean it up real good. Will the gaskets that are under the runners where they meet the motor, be ok or are there and gaskets there?
Then don't take apart the runners. The way I feel about reusing the metal intake manifold to head gaskets is that if you don't have a new set ready to go in there then you'll find that is the time that the black paint has decided to flake off of the installed gaskets. In other words always make sure you have a set of new replacement metal intake gaskets before starting that job. Once you've got the intake removed then you can decide whether you want to reuse the installed gaskets or not.KentuckySHOoff:
I have a set of gaskets that are for the intake but I don't think that I have any for between the heads and runners? squint
Oops, I read what you said wrong. Since you already have a set of gaskets for the intake manifold pieces then you can just buy two intake manifold to head gaskets from FPN for I think $10.50 each or so. Shipping's a flat $7 so if you can think of any other motorcraft parts you need then that would be a good time to buy them. Maybe a new upper and lower radiator hose?KentuckySHOoff:
