removing stock foglights...
Kilty423
Sho-fer
Pennsylvania
Whats the easiest way to remove them. I had **** of a time, very little room. I am guessing that i have to take the bumper cover off or something? I am going to replace them with pilot foglights.
frosho
WOLFMAN
Tyngsboro, MA
You could take the cover off if you want, but I think it would probably be easier to leave it on and just make use of whatever space is down there already. Are you talking about just the lights, or their brackets too?
SHO_DOODmorrris
Owner & Fanatic
Alberta
... it took me a 1 min to take each off. i forget what size the socket it but take a small ratchet down under and take off the nutz on the back of the springs that hold it on. unplug the pigtails and voila.
-Mitch
adidas_kn
LOWSHO
Houston Texas
The stock brackets that hold the smaller foglight brackets to the bumper support are heavy as ****. It's hard to get them off with the bumper cover on. There are 8 or 10mm bolts holding them to the bumper support. There isn't enough room to fit a ratchet with socket soo you wil lhave to use a wrench and turn it for like 3 days cause the bolt is most likely rusty. I used a ratcheting wrench. Made life allot easier. It would be better to remove them like I did and just drill the new foglights brackets to the bumper cover or something. Then make a semi support to keep it steady. The Fog light holes are pretty sturdy soo the aftermarket lights should be pretty stready bolted to it.
SHO Continental
Moderator
Northridge, Cali
On my '93 I did away with the entire unnecessarily heavy brackets with pilot foglights.
Dsc14582
Dsc14590
On my '95 I just trimmed the brackets and used the stock lights.
P1010008
P1010004
P1010005
Kilty423
Sho-fer
Pennsylvania
Ok thanks guys for the input, whenever the weather gets better i will try to tackle this. There is hardly any room to work.
Kilty423
Sho-fer
Pennsylvania
Well guess what....those nuts are rusted fasted to the bolts. I am just gonna dremel them off screw it, i am not gonna use them or the bracket for that matter lol.
