Removing passenger side Vent on dash?
T
ThatSHOkid
Guest
i know how to remove the other 2 (one on left of steering whell and the other underneath the Climate control unit that actualyl has 2 vents side by side) but how does this vent come off. i figured i would check with you guys before i started working on it. the reason why i want to take it out is i want to get a new vent since this one the adjustbale things are kind of broken on it.
1993 White/Tan SHO MTX 95k Miles
[*] Superwhite Headlights, Reverse Lights, & License Plate Lights ** Colgan Custom Bra From Cincy SHO ** Windshield Banner That Says "SHO" in Gen. 2 Font. ** Superchip Performance Chip ** Blacked Out "SHO" Lettering ** Sho Shop Y Pipe ** Coneless, Boxless w/K&N Filter Charger ** Blazertech Super Clear 55w Foglights ** Sunroof Wind Deflector & Vent Guards ** GTS Headlight Blackouts (on order) ** Sony 10 Disc Changer ** All Possible Options
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Strut Tower Braces, & A Sig Pic!
[*] My name: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
nothingtoseehere
Have the same problem on mine. The vent just pops off. Get a screwdriver in there and just pry it gently, and be carefull not to crack the dash around it anywhere.
-RANDY-
T
ThatSHOkid
Guest
i was looking at it and it looked like all i had to do was pry it, but i just wanted to make sure you guys said the same thing that i had thought. i didn't want to break it or anything.
thanks again
faxon
Seattle, WA
This is very hard to describe without pictures, but on the top and bottom of the vent, there are 2 plastic stops that need to be pushed down at the smae time, about 3/4 inch in from the outside. Once you pop the top or bottom out, wedge something in between the vent surround and the dash to prevent it from popping back in, work the other side out. This is a job that if done hastily will dent the vent edge and crack your dash. I think there's probaby a ford tool out there that makes this a whole lot easier. FYI if you are removing the vent with intent to discard it, it's faster and easier to break/bust the whole "grille" out, then pull the stops in fron the inside. This is a good thing to practice at the junkyard on a random taurus. Don't be a schmo though, pay them the 5 bucks they want for the vent you destroyed practicing the first time on, if you are like me. but they just saved your dashboard. It's worth it.
Good luck.
T
ThatSHOkid
Guest
how easy is it to put one back in? my existing one is kind of broken so i figure i will go to a junkyard and get one.
faxon
Seattle, WA
It pops in. As I said, it is really hard and confusing to describe this without any pictures, if they put it together, there's always a way to get it out.
