Removing ABS..(see locked thread)
38SHO
#1 Oil Abuser
North Palm Beach
so in the locked thread about switching over to ABS, I see someone mentioned getting brake lines for 200 bucks, but only for a non ABS car.....
can you tell me where that is availble at?
anyone ever converted an ABS car to the non abs setup?
mine doesn't work anyhow, i've scanned it haha... LONG list of codes...
the computer and wiring harness for it take up some room on the driver side engine compartment....... Some of my brake lines have been repaired and look to leak slightly anyhow..... upgrading to new brake lines would be a plus.
Would this be as simple as changing the brake lines over? Then could I just gut everything related to the ABS?
this would actually be pretty cool to do in my mind
*EDIT*
P.S. PLEASE don't turn this into a ABS vs non ABS or the advantages of ABS systems type of thread.. I'm specifically asking for more information about the new non abs hard brake lines, and removing the ABS system from the car........ yes I'm aware that this could cause my tires to lock up under bad situations....... thank-you
Jarrod
OK SHO - now in TX!
Midland, TX
Bob Gervais converted his old 91 to non-ABS. If the TCCA was up right now, you could check over there, as I think I recall him posting about it over there. You might shoot him a PM over here. He is a member here, too. He's a busy guy though, so I wouldn't get upset waiting for a response.
