Dr.Evil
No Dif Pin!
I am going to be rebuilding a motor soon, and just want to make sure I get everything I need before I get started. So far this is what I have done/getting done to the motor (all of this has less than 16K on it):
3.0 Bored .030 over. Improper hook-up when installed washed the rings and slightly scored the cylendar walls. I will get it honed and cross-hatched, hot tanked, etc.
Ballanced rotating assembly
Custom Ross forged pistons
crank turned .10 under and indexed
port matched heads (rebuilt)
ARP rod cap bolts
New oil pump
Now here is my list of stuff I need to get:
Rings
Rod Bearings
Upper Gasket Set
New Head Bolts
Front & Rear Main seals
Coolant hose set (7 total I think)
Pan gasket set
Thermostat
Water Pump
Clutch, TOB and new Fork
Accessory belts
Main Bearings
I already have the following:
All New or newer (less than 1 year) sensors minus oil lever sender, ETC, & oil presure sender.
Timing belt
Okay, what am I missing from the "to buy" list?
Also, does anyone have a complete list of all of the Felpro Gaskets that are needed for a complete overhaul?
<small>[ February 29, 2004, 07:05 PM: Message edited by: Dr.Evil ]</small>
ARP rod cap bolts
New oil pump
Rings
Rod Bearings
Upper Gasket Set
New Head Bolts
Pan gasket set
Thermostat
Water Pump
Accessory belts
Main Bearings
Timing belt
