Eliw
Ok, so my 89 has got its stock foglights.
I dont plan on buying new ones, so I just want to wire them diffrently to stop all the power from running through the MFS
. I know that the wiring to one of them is shakey because if I turn them on, it wont turn on unless I touch the cable
. So, I was planning on setting up a direct to battery relay harness to use on them. I want to connect the lead that works and use that one to turn both of them on. I plan on setting up the harness with a relay and with power going straight from the battery to the lights. Thing is I want to keep the stock switch. Is it possible
? Also, anybody know the wire setup of the fog switch on an 89? Its diffrent from the later years. Thanks
Why anyone would want to do that is perplexing.
Oh, and you still get to keep your rear defroster working as how it was intended by the bright intellectuals at FOMOCO.
