Ran codes, and Surprise!
FordLover
Houston, Tx
A buddy ran the codes on my car with the KOEO test, and it showed a 542 - Fuel Pump Secondary Circuit Fault.
The check engine light has only come on once since I've owned the car, and it happened about 3 months ago. As soon as a turned the car off, and restarted, it never illuminated again.
Can anybody shed some light? BTW, the car is running great, on open road, even the way I drive I've gotten 26 MPG, it will turn 14's at the 1/4 mile, and runs smooth all the time.
-Martin
Mike Kopstain
Arlington Heights, IL
If your car has stalled your computer will store that code. No worries! thumbs_u
<small>[ April 06, 2002, 01:08 AM: Message edited by: Mikeys_Taurus ]</small>
Martin,
Yes, the 542 is the "stall" code. To clear the memory codes, rerun the EEC test and pull the jumper while the codes are being output.
FordLover
Houston, Tx
Mikeys_Taurus:
Thank you Mike and Scott. I thought that might be what the code was, but was informed otherwise. So I brought it here, and my suspitions were confirmed.
-Martin
crystizel
