Ran Codes Again....
SASHO91
Zoom Zoom
San Antonio,TX
this Time i did it because i had an idle problem...
her it is..
KOER
412-idle speed not controlling idle... (duh)
and 116(engine was cold) and the 225 from the last time.
KOEO
111... its all good...
then stored was
173
177 which is the front and rear o2 sensors, which i understand, cause thats when i couldnt get her started...
then
219- spout..... ??? havent figured that out yet.... was on last test.
then
542- which i stalled her out.... oops...
the only one im concerned about is the 412... could i have messed up the idle control valve? I cleared the codes, when i was done. oh the balance test was a Perfect 9!!! :hail:
thanks guys...
Ishodu
You should clear your codes and read them again if you didn't last time. You may have a bad or dirty IAB valve. And did someone maybe un plug the spout to help it pass emissions? Try a search on this you should find a pic of what the plug looks like prolly just have to plug it back in.
SASHO91
Zoom Zoom
San Antonio,TX
The spout is connected. Which leads me to believe that i have a grounding problem.....
As for the codes, i havent run them yet. but, i cleared the codes by removing the paper clip while the codes were being read, is this right? If so then my codes are clear. Then i will go out run them again. thanks....
