Radiator woahs........I think.
Random
Westlake, Ohio
Ok, I am confused. here is the situation.
In the summer, when it got really hot out, my temp needle would go real high. In between the O and R. but never above. so I didnt let it bother me.
Now that it is almost 20 out, the temp of my car stays very very low. It rarely rises above the first line above the C. Also, when i first start my car, a low coolant light comes on, but I have plenty of coolant. After the car has been driven and "warms" up. I restart it and no low coolant light. what does this all mean?
fredhurderjr
www.neshospecialists.com
I just replaced the t-stat & temp sender in my 91. It was staying on the line at "C" also. After, it works fine. Do them both once you're in there - they are right next to each other.
I believe it's the RT-1112 t-stat & SW-2328 (??) sender, from memory. Check it out at fordpartsnetwork.com or shonutperformance.com. Good luck.
White 95 SHO MTX
"Jezebel"
Teases me with occasional great runs in between break-downs.
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
Hi-Revs Jr. Clutch
Dynomax Cat-Back
"The Reliable Winter Car"
Blast7
Rochester, NY
I would replace your thermostat and temp senders if it has been a while just for preventative maintenance. I would be surprised if your temp gauge went to the O because once my temp gauge reaches R the fan turns on.
Car of the Week
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
